Perform this procedure to enable Energy Saver globally on the switch. You can optionally configure PoE power savings, to power off low priority PoE devices during off-peak times.
  • You must enable Energy Saver on individual ports.
  • You must create an Energy Saver schedule.
    enable
    configure terminal
  2. Optional: Configure PoE power savings:
    energy-saver poe-power-saving
    You must configure PoE power savings before you enable Energy Saver globally.
  3. Enable Energy Saver:
    energy-saver enable
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#energy-saver poe-power-saving
Switch:1(config)#energy-saver enable
The following table defines parameters for the energy-saver command.
Variable
Value
enable
Enables Energy Saver feature. The default is disabled.
poe-power-saving
Enables PoE power saving. The default is disabled.
